Skoda Yeti 2012 A Panel Inner Trim Removal
Hi I need to remove the outer trim on my windscreen A panel due to damage. Understand to do this I need to remove some torx bolts on the inside of the A Panel. It looks like the inner is a a white plastic trim to remove but do I just tug at it from the top ? or is there a preferred way to remove it.
Thank you
If you want to remove the white inside A trim, then just prise it away gently so you can get your fingers under it and then pull firmly. It's clipped in place, but unlikely to break unless you go stupid with it.
Be aware there is an airbag beneath it so don't poke sharp tools in there!
