Anyone put 2018 (B9) RS4 20" Alloys on a 3V5 Superb?
Hi All, bit new to the Superb life, but a friend is selling the alloys off his 2018 RS4 and I think they'd look awesome on my wagon, but unsure if they'll fit. Wil.theyfit.com says the rims will stick out an additional 30mm - which seems ok on the rear but looks way too much on the front. Would likely need narrower tires than the factory 275/30/20's the RS4 is running currently. The main problem as I see it is the RS4 alloys have a 26 offset, which is a bit much. In before the "+35 is maximum" comments!
Anyone seen this in their travels and know if it's liveable or a nuisance. this is my everyday wagon, and I'm too old and tired to put up with rubbing tires and all that malarky.
thanks in advance!
On their own the increase in width or offset would be fine but together it's just too much. The spacers I'm using to clear the Brembos result in an effective ET29, you could probably just squeeze an 8.5J in there as well but it would be tight.
Yes, you could probably get them to tuck with surgery and some serious camber, but that's a long way down the "form over function" road.
