wing mirrors adjust
My Skoda 2022 has wing mirror adjustment that either does not work or partially works.
When I try to adjust the mirror manually, on both sides, they feel hard to move.
Not sure if its electrical or a mechanical issue.
Most likely the mirror switch.
I, amongst others, have either had this replaced or cleaned the contacts due to the behaviour you describe.
Hope that helps!
Add me to the list, my mirror switch is sometimes reluctant to behave as it should.
I get an "implausible" signal on VCDS, I will remove it and clean sometime soon, and see what happens.
At the same time I plan other work on the door ... soon will expand on this!
I've had this on both my kodiaq and superb, I fixed both by levering out the switch and spraying contact cleaner onto the switch connector contacts, only takes five minutes...
