Wiring diagrams Rear view mirror auto dim and HBA.
My rear view mirror has auto dim and high beam assist camera.
HBa has faulted and I'm trying to see if a testing company might see if the can find the fault as below from VCDS SCAN.
Revision: AA001001
 Coding: 01028F6B76765D525220343E01
 Shop #: WSC 73430 031 00000
 ASAM Dataset: EV_HighBeamAssisAU37X 001009
 ROD: EV_HighBeamAssisAU37X.rod
 VCID: 2B02F850438DDB320B1-807E
1 Fault Found:
4186894 - Internal Control Module Memory Check Sum Error
 B2000 47 [00001001] - Watchdog/Safety µC Failure
 [Steuergerät: defektECU: defect]
 Confirmed - Tested Since Memory Clear
 Freeze Frame:
 Fault Priority: 3
 Fault Frequency: 1
 Mileage: 174461 km
 Date: 2025.01.14
Be handy if someone had the wiring diagrams available to send me, so if I send it to them they can apply some power/canbus signal input to it for fault finding.
The Controller is damage. Replace IT, all Other is waste time
