Simultaneous Crash Sensor Faults?
Hi all,
Long term lurker (without account), first time poster.
My partner (used to be my car) has a 2008 Superb 2 CBBB DSG SE spec.
I’m wondering if the collective hive mind could help me, or the very least point me in the right direction?
I’m getting multiple crash sensor driver and passenger faults in VCDS, indicated by an airbag MIL.
Could this be a faulty ABS module due to crash sensor faults on passenger and drivers side? And the sub system serials showing “000”? Is there common issues or any known locations to look for? Could loom fatigue at the door hinge cause this? Though I can’t see both sides having the issues exactly at the same time.
I will check behind the radio as that was removed and refitted about 11 months ago.
Any input would be fantastic!
Fault codes below
 Address 15: Airbags
Labels: 5N0-959-655.Ibl
Part No SW: 3Т0 959 655 HW: ЗТО 959 655
Component: J234_LAJ VW10 HI 1815
Revision: 17013000
Serial number: 003CCPDLK93W
Coding: 0016714
Shop #: WSC 33361 790 00999
VCID: 7EF34BFF29F77C66B1-802A
Subsystem 1 - Serial number: 00000000000000000
Subsystem 2 - Serial number: 00000000000000000
Subsystem 3 - Serial number: 00000000000000000
Subsystem 4 - Serial number 00000000000000000
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
5 Faults Found
01221 - Crash Sensor Side Airbag; Driver Side (G179)
010 - Open or Short to Plus - MIL ON
Freeze Frame
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 214212 km
Time Indication: 0
Date: 2020.04.10
Time: 08:12:02
01222 - Crash Sensor Side Airbag: Passenger Side (G180)
Freeze Frame
Fault Priority 2
Fault Frequency: 1
Reset counter 33
Mileage: 214212 km
Time Indication 0
Date: 2020 04 10
Time: 08 12 02
01638 - Crash-Sensor for Side Airbag: Rear Drivers Side (G256)
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 214212 km
Time Indication: 0
Date: 2020.04.10
Time: 08.12:02
01639 - Crash-Sensor for Side Airbag: Rear Passenger Side (G257)
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 214212 km
Time Indication: 0
Date: 2020.04.10
Time: 08:12:02
01738 - Crash Sensor for Front Airbag: Drivers Side (G283)
Freeze Frame
Fault Status 11101010
Fault Priority: 2
Fault Frequency: 1
Reset counter 33
Mileage: 214212 km
Time Indication: 0
Date 2020 04 10
I also have odd faults with the central electrics too. The rear light is a dodgy cable to the very side light on the rear cluster and the front dipped bulb was replaced last week.
 Address 09: Cent Elect. (J519)
Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 A
HW: 1K0 937 086 A
Component: BCM PQ35 M+ 020 0360
Revision: 00020000
Coding: 489B0AB8D861F1C040080084110081A407791BAE4320816
Shop#: WSC 25087 526 92301
VCID: 2E53BBBF79174CE661-807A
Subsystem 1 - Part No: 3T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 15070 22 0602
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 659 AH Labels 1K0-955-559-AG.C
Component: RLS 240708 05 54 0402
Coding: 0730ED
Subsystem 3 - Part No. 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 961 605 C
Component LIN BACKUP HO H03 1301
01134 - Alarm Horn (H12)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 00100010
Fault Priority: 4
Fault Frequency 5
Reset counter: 62
Mileage: 211521 km
Time Indication 0
Date 2020.04.10
Time: 18.15.54
Freeze Frame
Term 15 On
Voltage 10.45V
ON
ON
Term 50 On
ON
ON
00985 - Right Tail Light (M2)
014 - Defective - Intermittent
Freeze Frame
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 100
Reset counter: 73
Mileage: 211937 km
Time Indication: 0
Date: 2020.04.10
Time: 20:05:59
Freeze Frame
Term 15 On
Voltage: 13.40 V
ON
ON
Term 50 Off
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame
Fault Priority: 6
Fault Frequency: T
Reset counter: 69
Mileage: 213616 km
Time Indication: 0
Date: 2020.04.10
Time: 18:52:58
Term 15 On
Voltage: 10.20 V
ON
ON
Term 50 On
ON
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 7
Reset counter: 65
Mileage: 213956 km
Time Indication: 0
Date: 2020.04.10
Time: 15:17:19
Term 15 On
Voltage: 13.85 V
ON
ON
Term 50 Off
OFF
ON
Thank you all
Edited by Skoda_Simo
