Drivers footwell very wet
The drivers footwell in my 2009 Octavia estate is very wet, when I push my foot into the carpet there is a massive pool of water.
This is causing condensation on the windscreen which is difficult to clear as the blower won't blow hot air.
Are there any obvious causes for where the water is getting in?
Thanks,
Paul
@pw2112
Paul,
It could be a few things:
Based on the details you've provided and the search results I've reviewed, there are several common causes for water ingress in vehicles like your 2009 Skoda Octavia estate. The issue with your blower not producing hot air is also a known consequence, as serious water ingress can lead to electrical problems.
Here are the most likely sources of the leak for you to investigate:
Potential Cause Description & Key Clues
Blocked Scuttle Drains 🍂 The drain channels under the windscreen wipers (scuttle panel) clog with leaves. Water overflows into the cabin, often near the pollen filter.
Faulty Pollen Filter Seal The seal around the pollen filter housing (located in the scuttle panel) can fail. A displaced or cracked cover lets water drip directly into the footwell.
Failed Door Membrane 🚪 The plastic moisture barrier behind the door card can perish or become unsealed. Leaks from doors often soak the lower carpet.
Leaking Rear Washer Pipe The pipe to the rear window washer can crack or disconnect, leaking water that runs along the floor to the front.
🔧 A Step-by-Step Guide to Finding the Leak
Given that your blower won't blow hot air, it's crucial to address this promptly to avoid more costly electrical repairs. Here is a logical sequence to track down the source:
1. Inspect the Scuttle Panel Area First: This is the most common culprit. Open the bonnet and look at the area at the bottom of the windscreen, where the wiper mechanisms are.
· Clear the Drains: Remove any leaves, twigs, and debris you find. Then, slowly pour a small amount of water into the drainage channels and see if it drains freely out near the front wheels. If it's blocked, carefully clear it.
· Check the Pollen Filter: The housing for the cabin pollen filter is located here. Check if the waterproof cover is cracked, misplaced, or improperly sealed. A faulty seal here would allow water to flow directly into the passenger footwell.
2. Inspect the Door Seals: If the scuttle area is clear, the next step is to check the doors.
· Remove the interior door card to inspect the plastic waterproof membrane behind it. On older VAG group cars (like Skoda, VW), this membrane can perish or come unglued, allowing water that enters the door to leak into the cabin.
3. Check the Rear Washer Pipe: This is a very common issue in estates and hatchbacks.
· Have someone operate the rear window washer while you listen in the footwell and along the door sills. If you hear gurgling or see water, you've found the leak. The pipe can disconnect at joints under the dashboard or along the sill trim.
4. Don't Forget the Sunroof: While your search results didn't mention one, if your car has a sunroof, its drain hoses (which run down the A-pillars) can become blocked or disconnected, causing water to dump into the footwell.
🚨 Immediate Actions You Should Take
Before you find the source, and to prevent further damage, here's what you should do right away:
· Remove the Water: Soak up as much water as possible with towels. For the large pool under the carpet, using a wet/dry shop vacuum is the most effective method. This is crucial to start the drying process.
· Dry the Area Thoroughly: After extracting the water, promote drying by lifting the carpet if possible and using a powerful fan or a dehumidifier in the car for a day or two. Lingering moisture will continue to cause condensation and mold.
· Address the Electrical Issue: The problem with your blower not blowing hot is likely related to water damage. Moisture can corrode connectors and control modules under the seat or dashboard. Once the area is completely dry, the electrical function may return, but corroded components may need professional inspection and replacement.
Not my work but an AI that I use
Hopefully it’s helpful
John
Wow!
That's a very detailed response, thank you very much.
I will work through your suggestions. It's only the front drivers footwell that is sodden so I will start with the scuttle panel first.
The temp gauge on the dash gets up to temp and sits at just above 90 but the blower won't blow hot.
I changed the pollen filter on the passenger side recently, I'll check it's seated in properly.
The boot is dry and the rear washer works so I don't think I have an issue with that.
Thanks again for your suggestions,
Paul
If you have a Climatronic heater then you can use the humidity control feature to help dry the car (and also clear the windscreen fast).
Just set the temperature to where you normally have it but with the blower a bit faster. Then make sure the air conditioning is set to ON.
I know it sounds daft but the water is removed by the cold side of the A/C before being heated to the set temperature. Leaving it on recirculation for short periods will help.
Thanks, I wasn't aware of that
Additional to my post above, on most models you will see that the a/c compressor is switched on automatically when you press the "max air to screen" button if the humidity is high.
The water in the humid air is condensed to liquid water by chilling and then runs down a pipe to the outside.
