3 fault codes AAC
Hi, can someone explain me whats the problem here and how to solve this issue ? someone with the same issue in the pass ? it is Scanned with VCDS with a Engine running. so it is not a Battery issue.
Adress 42 is already solved yet!
Tuesday,25,November,2025,20:19:23:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 25.3.2.0 HEX-V2 CB: 0.4672.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: -------------------- License Plate:
Mileage: 161938km-100623mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 18 19 42 44 52 5F 69 BB BC
VIN: -------------------- Mileage: 161938km-100623miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 BA HW: 04C 907 309 BP
Component: R3 1.0l TFS H20 7059
Revision: DGH20000 CVN: 89E5DBD6
Coding: 0119003A243419080000
Shop #: WSC 31000 790 00225
ASAM Dataset: EV_ECM10TFS01104C906025BA 003001
ROD: EV_ECM10TFS011_VW37.rod
VCID: 6099A09DDAC05DDAEE3-8034
VINID: 91D49A8077950DC0001471001CFA92C573
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 EQ HW: 5Q0 614 517 BM
Component: ESC H45 0190
Revision: 00000000 Serial number: 62619000000258
Coding: 25076A9120252173407B060060CA24A456048402600624723023F070D0024B0B0000000012121212B835351919323200
Shop #: WSC 31000 790 00246
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 04518C0D2E98E1FAAAB-8050
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5E0 907 044 BC HW: 5E0 907 044 BC
Component: Climatronic H04 2201
Revision: 00001K00
Coding: 02010004004111011005000800101026
ASAM Dataset: EV_ACClimaBHBVW37X 006150
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 678BBB813FEE2AE22F9-8032
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DG HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H40 0312
Serial number: 01001925702074 Dataset Number: V03935312BB 0001
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 0059801D3A80FDDA8E3-8054
Wiper motor control module:
Subsystem 1 - Part No SW: 5E1 955 119 A HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 190829 051 0916
Serial number: 887353F0401924102277
Coding: 065DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SBY19M09D12H00M46S56
Coding: 00885D
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 B HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000008091920240449
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058419262 Dataset Number: V03935291WR 0001
Coding: 0471051141
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 50F9705DAA60CD5A5E3-8004
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Dataset Number: V03935269HY 0001
Coding: 2B00600941FFC728949C810500400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D14C0D6E1821FAEAB-8010
3 Faults Found:
0828 - Databus
U1123 00 [00001000] - Received Error Message
[FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 60
Mileage: 161602 km
Date: 2025.11.22
Time: 09:03:49
Control Module temperature: 0 C
Voltage terminal 15: 10.3 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s
Status_ACC_System: ACC_reversible_error
0822 - Databus
[FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 60
Mileage: 161602 km
Date: 2025.11.22
Time: 09:03:49
Voltage terminal 15: 10.1 V
1074 - Databus
U1121 00 [00001000] - Missing Message
[FAULT_TIMEOUT_ESP_33]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 60
Mileage: 161602 km
Date: 2025.11.22
Time: 09:03:49
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PHC1U84 Dataset Number: V03935312NR 0001
Coding: 98CCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0B43A73103C6AE82EB1-805E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 001 708 19
Component: SideSensor_Df 008 0887
Serial number: 35700000000EA5E02F3Z
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 2 - Part No SW: ----------- HW: 454 001 408 19
Component: SideSensor_Pf 008 0887
Serial number: 35800000000D20212F3B
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 454 802 208 19
Component: SideSensor_Dr 301 0148
Serial number: 35100AAF94719000000V
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 454 802 108 19
Component: SideSensor_Pr 301 0148
Serial number: 352006D284819000000I
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 454 802 708 19
Component: FrontSensor_D 304 0149
Serial number: 35500B33192190000009
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5E0 920 750 F HW: 5E0 920 750 F
Component: KOMBI 312 2800
Coding: 07A50A002180000801886A011001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 270BFB81FF6EEAE2EF9-8072
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 K HW: 5Q0 963 272 K
Component: STH-MQB 008 0080
Coding: 1309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 3E253EE500F44B2ABCF-806A
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0402
Serial number: 00000000000000832284
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000096223 Dataset Number: V03935304QL 0001
Coding: 030100347F08570021100240000F00010001070000000000000000000000
GVL: 01443C0000000000C00C80000004480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: 70B9D0DD0A20ED5A7E3-8024
Generator:
Component: 5-01-14-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E
Component: E221__MFL-PR6 H03 0180
Serial number: 000000000E0608170919
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003001909110297
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 393 K HW: 5Q4 959 393 K
Component: TSG FS 007 0485
Serial number: 0000389300308 Dataset Number: V03935304DK 0001
Coding: 001001208000020000001100
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 4BC367314346EE822B1-801E
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 407 A HW: 5Q0 959 163 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000033934333
Coding: 010200
1 Fault Found:
196660 - Motor for Window Regulator
B1487 54 [00001001] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 22
Mileage: 161870 km
Date: 2025.11.23
Time: 13:44:25
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 957022 00 Dataset Number: V03935289KQ 0001
Coding: 0100001000400010
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2.rod
VCID: 2B0307B1E386CE820B1-807E
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 392 K HW: 5Q4 959 392 K
Component: TSG BFS 007 0485
Serial number: 0000389181143 Dataset Number: V03935304DN 0001
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 4ACD62354C3CF78A107-801E
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 408 A HW: 5Q0 959 164 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000033743660
Coding: 190200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 565 035 874 HW: 565 035 874
Component: MU-S-ND-ER H41 0480
Serial number: SKZAZ2W1033306 Dataset Number: V03935300WY 0001
Coding: 03730201FF00000041111201008802002F0208C401200500CF
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 5BE39771F3A67E02BB1-800E
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5E0 919 605 M HW: 5E0 919 605 M
Component: ABT_Std-2_Nav H61 8214
Serial number: SKZ6ZHW2691268
Data carrier:
Subsystem 2 - Part No SW: 5L0 051 236 EG HW: -----------
Component: ECE AS 2026 --- 2510
Serial number: --------------------
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0528260565 Dataset Number: V03935225DF 0001
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW37.rod
VCID: 40D9401D7A003DDACE3-8014
End----------(Elapsed Time: 01:28, VBatt start/end: 14.7V/14.7V)-----------
------------------------------4 Faults Found-------------------------------
Module 13 is telling us that the Sensor at the front of the car - the ACC sensor - has failed. Its tested it numerous times, but the module either doesn't respond or is not responding correctly.
what can cause something like that ? is it just a defect in the sensor or maybe dust on it ? and is it easy to swap for a newone ? i suppose it has to be recalibrated once it's swapped ?
Edited by Naudje32
Not dust. Electrically, they just die. Not super common on ACC sensors, but they do fail none-the-less.
Yes, it will need to be swapped out and yes, it will need to be coded into the car.
i will try to read it out with odis to see.
