2025 RS - 17" winter wheels and snow chains?
I am picking up my 2025 RS next week on the standard 19" wheels. I am driving to Austria immediately after and need snow chains.
The manual states that chains are only permitted on 205/55 R17 tires. I am planning to buy 17" rims for this reason. I realize they will look small, but practicality is the priority here.
Has anyone used snow chains on the RS? Any experiences to share?
Thanks in advance for the help!
Do 17" rims actually fit with the vRS discs?
The biggest front brake discs on the Octavia MK4 are 340x30mm, so 17" rims will clear the front brake calipers.
If 17" rims didn't clear the 340x30mm front brake discs, you wouldn't be able to use snow chains...and it wouldn't make sense for Skoda to sell such a vehicle.
Technical data (from Octavia MK4 owner's manual)
Permitted rim/tyre combinations for mounting of snow chains:
Rim size
Tyre size
6.5Jx16 ET46
205/60R16
6.5Jx17 ET46
205/55R17
Only fit snow chains with links and locks that are no larger than 9 mm.
SKODA ACCESSORY CATALOGUE
The Skoda accessory catalogue lists four 6.5Jx17 ET46 5/112 57.1 alloy rims for the Octavia MK4, as follows. They can be ordered from any VAG parts department by quoting the relevant OEM part number, eg. 5E3071497AC 8Z8, etc.
6.5Jx17 ET46 5/112 57.1 LYRA alloy rim 5E3071497AC 8Z8 (Silver metallic)
Alu kolo Lyra 17“ Octavia IV
6.5Jx17 ET46 5/112 57.1 LYRA alloy rim 5E3071497AD FL8 (Black metallic)
Alu kolo 17“ Lyra Octavia IV
6.5Jx17 ET46 5/112 57.1 NEVIS alloy rim 5E3071497AA 8Z8 (Silver metallic)
Alu kolo Nevis 17“ Octavia IV
6.5Jx17 ET46 5/112 57.1 NEVIS alloy rim 5E3071497AB FL8 (Black metallic)
google "skoda eshop cz"
https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3ApriceAsc%3ArimDiameter%3A17%2522%3AcarType%3AOctavia%2BIV%2B%25282019%252B%2529&text=#
google "skoda parts com"
https://www.skoda-parts.com/catalog/octavia-4/spare-parts/accessories/wheels-steel-aluminium/aluminium-wheel/17-895.html?sort=cheapest
Edited by Carlston
