Skoda Fabia 2013 control box, booth lock connection.
Merry Christmas for You all!
One question about control box in my Fabia. Sometimes I have problems to open booth lock. Button works but lock won't open. Button and lock are ok, I have tested them. And the cable is ok in the rear lid. Finally I found, that when I move control box and cables around it, boot lock works again. I can repeat this so problem is there. Unfortunately I don't have any drawing so I have no idea which pin in the control box goes to the booth lock. Control box is located in the front, above the pedals. The are two big connectors in that box, white and black. It could be a soldering probled in the circuit board or a bad connection in one of those pins. It would be easier if having diagram for those pins. I would be happy in there is a drawing somewhere.
Edited by Doingitmyself
Have a look at the connectors to the box to make sure the pins/spade terminals are making a nice tight connection and the plugs are going all the way in. If it changes when moving wires then it may be a break somewhere as well or perhaps a poor earth
Alasdair
