Retrofit OEM LED Headlights for LHD
As with the Octavia, the Kodiaq is slated to receive OEM LED headlights as a retrofit project planned for 2026.
Required materials:
LED headlights, part number: 566.941.015.F
LED headlights, part number: 566.941.016.F
LED ballast, part number: 7P5941591AJ
LCM or multi-function control unit, part number: 3Q0907338C
Rear axle sensor, part number: 5Q0907503
Windscreen washer fluid reservoir & headlight washer system, part number: 5NA955449
This is a very rough estimate, and the front bumper with headlight washer system (part number: not spzecified as it varies considerably) is not included.
Since the Kodiaq already has a 14-pin connector, unlike the Octavia 3, I intend to fabricate the necessary wiring harnesses myself, using OEM wire colors based on the wiring diagrams.
All information and part numbers are orovided without guarantee of accuracy.
Edited by Cairus
  • Cairus changed the title to Retrofit OEM LED Headlights for LHD
First Test
I don’t believe you need the headlight washer system and associated parts.
My LED headlight Kodiaq didn’t have washers, but my Yeti with HIDs did.
My Kodiaq 2 has LED headlights and also doesn’t have washers fitted.
In Austria Always with This parts
So, wiring harness 4B and the wiring harness for the axle sensor are mostly finished.
Today I ordered more colored wires so I can complete the wiring for 4B to the headlights.
Connector 4B still needs to be replaced; it's just my wiring harness test connector.
Then I can finally start the Retrofit
I gathered some important information from the retrofit in the O3 so I don't make the same mistakes again.
Edited by Cairus
Yesterday, work continued at the "table."
The Kodiaq data set was loaded, and the coding was prepared as far as possible from the 4B unit.
So, the project is slowly progressing as the weather gets nicer.
Next order placed:
22 automotive wire spools, each 25m long, in the same color and cross-section as the OEM wiring for the LED headlights.
This will allow us to produce the last two wiring harnesses.
The first LED headlight wiring harness is almost finished; only the 14-pin connector and the small pins are missing.
Though not yet finished, awesome job!
My free time Job, i like it.
Headlight wiring harnesses manufactured and a full table setup carried out with unit 19,4B,09,D6&D7 etc. etc.
  • 6 months later...
Hi Cairus,
I'm currently converting my 2017 Škoda Kodiaq to the 2021–2022 facelift version. I have purchased both facelift LED headlights, but the original wiring connectors are not compatible.
My headlight part numbers are:
  • Left: 566 941 035
  • Right: 566 941 036
  • New control module: 992 941 572 CA
  • Original control module: 7P5 941 591 AD
I'm looking for a complete plug-and-play adapter harness for both headlights, without cutting the original vehicle wiring.
Would you be able to manufacture these adapters, or help me identify the correct connectors and wiring?
Could you also advise whether additional modules or coding would be required?
I'm based in the UK. Please let me know if this is something you can help with and what the cost would be, including delivery.
Many thanks.
Did you have a look by Kufatec? They may sell plug and play adapters...
Plug & Play doesn't work here—not even with an adapter.
You don’t buy the components first and only then start thinking. Naturally, the vehicle has to be reprogrammed.
Are you aware that a new bumper is required? Likely also a new BCM module and an LCM module.
Edited by Cairus
Thanks for the information.
The facelift bumper and headlights are already fitted. The car starts, drives and runs perfectly fine. The headlights also power on and stay illuminated, but the indicators and other lighting functions aren't working correctly.
Do you know whether the original BCM and LCM can be reprogrammed, or whether they need replacing?
Would you be able to recommend a solution or supply the necessary parts? Alternatively, if this is something you can do yourself, I'm happy to bring the car to you and have you arrange the wiring, modules and programming to get everything working properly.
Thanks, Adam
@gold , AFAIK @Cairus lives in Austria. It may be a long way from home to bring him your car... 😉
Recently Browsing 1
