Sodden rear footwell
after a wet spell, inner car windows were wet. On inner car inspection found driver side rear footwell completely sodden! When I took out the mat it was dripping wet, still trying to soak up the water. I don’t have a sunroof and can’t find the sieve if the leak. Any suggestions please?
If the drivers side front is dry I would look at the seals of the rear door or perhaps seals around window. Mine used to leak due to the window seals leaking and also the protective plastic inner door liner becoming unattached. Check theres no rubber grommets in floor etc that are missing under carpet etc as well.
Alasdair
