CH/LH problem
Hello,
I’m having an issue with Coming Home / Leaving Home (CH/LH) lights on my Škoda Octavia Mk4 (2021, MQB Evo).
The function worked correctly before (last year and a few months ago), but now it no longer behaves as expected.
Problem description:
CH/LH does not activate when:
unlocking the car with the remote at night
opening the driver’s door in the dark.
Headlights and parking lights stay off
Only the mirror puddle lights sometimes turn on, often with a delay (≈5 seconds after closing the door), which seems illogical.
Interior lights work correctly when doors are opened.
Door status is correctly detected (door open/closed shows properly in live data).
No fault codes related to CH/LH, doors, BCM or light sensor.
Light sensor shows 0 lux in full darkness.
Vehicle status shows Night Mode = Active.
Previously CH/LH worked in the same parking conditions (street lights, shop parking lots, etc.)
What I have checked / done:
Verified CH/LH enabled in infotainment menu.
Checked Central Electronics / BCM coding and adaptations.
Checked Driver’s Door and Passenger Door electronics, all is correct.
Day/Night mode.
Ambient light values.
IR / Forward light thresholds.
Checked light switch coding and installation list.
No recent BCM update (only infotainment was updated).
Tested with OBDeleven and ThinkDiag
Looked for BAP / menu control channels related to CH/LH
No wiring issues detected.
No relevant DTCs stored
Confusing behavior
Sometimes mirror lights activate late
CH/LH does not activate even though:
Night Mode is active.
Ambient light is 0 lux.
Function clearly worked before with the same conditions.
QUESTION..
Has anyone experienced similar behavior after software changes on MQB Evo?
Is there a known BCM / light logic change that makes CH/LH more restrictive?
Are there specific BAP or CH/LH trigger channels that might disable CH/LH even when everything looks correct?
Should CH/LH still activate under street lighting if Night Mode is active?
Any technical insight is welcome.
Thanks.
Any suggestions?
Probably a daft suggestion, but you say you've checked to see whether they're enabled in the infotainment system, have you then checked the duration for which they're to be activated? Not currently situated in my car but I'm pretty sure that is an option, if you have that set to 0 (or equivalent) then could that be the cause..?
Edited by scotthugh3s
Checked that already – Coming/Leaving Home duration is set to 15 s in the infotainment, so activation time shouldn’t be the issue.
“I’m out of ideas at this point🙂
Given that the infotainment shows 15 s, I’m wondering if the BCM has any separate or overriding timing parameters for Coming/Leaving Home?
And probably just a daft suggestion as well, but what about disabling the setting and leave it off for at least one start/run session and then re-enable it, sometimes just turning things off and on again can fix them. Worth a crack...
I actually haven’t tried that yet yes. 🙂
I’ll give it a try tomorrow, disable it, leave it off for one full start/run cycle, then re-enable it and see what happens.
I’ll report back whether it helps or not.
In the meantime, if anyone has any other ideas, feel free to share them.🙂
Edited by Alo20
I tried that today (disabled it, left it off for a full start/run cycle, then re-enabled it), but unfortunately it didn’t change anything. CH/LH still doesn’t work.
Oeh
Does anyone have any other ideas on what I could check or look into?
I have access to VCDS, ThinkDiag 2 and OBD Eleven, so I can check things with those tools as well if needed.
  • 6 months later...
Hi again.
Still have the same probleem.🙂
Does anyone with a Skoda Octavia IV (2020–2022), where Coming Home and Leaving Home are working correctly, have a VCDS measuring values log from 09 – Central Electrics (BCM)?
I'm particularly interested in these values:
  • Sensor_Error1
  • Sensor_Error2
  • Sensor_Error3
  • Sensor_Error4
On my 2021 Octavia IV, the first three values are 0, but Sensor_Error4 = 1.
My Coming Home and Leaving Home functions are not working, even though the light sensor detects darkness correctly and the BCM adaptations appear to be correct.
I'd like to compare these values with a working Octavia IV to see whether Sensor_Error4 = 1 is normal.
If anyone could check these values or share their blockmap-09 CSV file, I'd really appreciate it!
Thanks!
