fuel injector over fuelling
Octavia 2018 SE 1.6TDI
Comes with no codes
runs rough from start up
smokey obviously missfiring on a cylinder
smoke clears after 5 minutes and runs fine
on live data injector number 4 is over fuelling we have replaced number 4 injector and still have the same issue also replaced the heater plugs
totally baffled )
Edited by tony1973
Was the new injector coded? Sorry if its a daft question
Alasdair
Edited by Alasdair1
Alasdair
yeah all coded in
Thats a weird one. Its a long shot but maybe a sticky/bad exhaust valve? Leaks when cold seals when hot?
Alasdair
Alasdair
Possibly Ill ask mechanic thanks
You need a leak down test on the injectors. But as with most MK3's they are all getting to an age where ALL FOUR INJECTORS need to be replaced. Don't replace just one.... because you will get failures on others very shortly afterwards. I know it's expensive but it will keep the car running for another 100k miles.
thanks for reply
