Fuse box does not match the diagram! Fabia Monte Carlo 2015
Hope someone can help as I am flumoxxed. Every fuse box diagram search I make (I have looked at every single owner's manual) is the same, three sections, clearly marked.
My car has a completely different layout! The headlights have suddenly both gone, I can't find a broken fuse, but I also have absolutely no idea which fuse is on which components.
Any suggestions please?
Oh thank God, I was starting to think some cowboy had installed something weird that no one had ever seen!
thank you very much indeed, this is exactly right. Thank you.
Hi, welcome.
On the VWŠkoda 'Owner Manual' site with free downloadable pdfs you can enter your car's VIN number which should take you to the correct 'Owner's Manual'. Then some of the diagrams in some of the manuals may have errors.
You have put your car as a 2015, I don't know but this might relate to the model year rather than the actual year it was made. A Mk1 and Mk2 look just about different on the outside to distinguish them, the Mk3 has sharper-edge folds in some body panels, particularly noticeable in the Mk3 hatch rear panel.
If you have a Mk2 then there will be lots of information and help in that section of the site, if Mk3 then here of course.
HTH. Good luck.
