DIN unit out
Any ideas on how to remove the DIN unit from behind the dash? I've struggled for an hour while trying to fit the reversing camera kit.
It's held firmly, I can't seem to lever it out, despite sliding an assortment of plastic ice scraper and trim removal tools.
Searched a thread on here which shows the same unit and a tool used but I cannot seem to work out how to acheive it.
https://www.briskoda.net/forums/topic/448440-fabia-mk3-2016-stereo-removal-instructions/
Can't seem to find explicit detail on what is securing it, but neother can I see any screws. It would logically be a slide-fit-latch but I can't see any of those either.
TIA
GB
It's the two DIN key removal holes! NOT a pry/trim tool of any sort.
Anyway, the #Sinosmart kit works. Connections at the back of the LCD display can be a little tempremental, but a solid push makes it all good again
Routing the video cable around the left B-pillar - requires careful use of fingers to route below and behind the airbag which deploys down and outward. This can be felt only, even use of a borescope reveals limited detail, only that the airbag is present along the interior ceiling rather than the left B-pillar.
Also, when routing the cable up the rear-left of the rear screen, a wire coathanger is readily available and works as a tool to poke then pull the attached yellow-ended video wire, but the pointy end MUST be wrapped in electricians tape or it will scuff the inside water-repellent coating of the metal.
