door thingy bust
this just popped out when mate shut the passenger door, dont know maybe its broken off, maybe need a new one...oh well...just thought i would share this with ya`ll
Mine broke off today. Fortunately I found it on the floor! It doesn't seem to attach properly when I tried to put it back on and is still very loose.
Also today my diesal flap broke so it no longer clips shut.
They al lfall off sooner or later..lol. I stick em back in.
And for your flap esvaq if you do a search its quite common.
i hate things that dont fit backin properly, hope the glue will hold
I'd be inclined to get a replacement rather than glue it on, Theres a Torx screw behind there that holds the door card on.
Ours fell off when we came back to the garage after the test drive. The dealer "fixed" it before we collected the car!
Don't know if it was replaced or glued. Which dealership do you work at Lummox?????
Bluetack works
One of the two problems I had with the car since new ;) - I popped it back in once, it happened again, then got the dealer to sort it out (probably glued it). Been fine since :thumbup:
Regards the flap - cable has unclipped itself, search & you will find :)
Bluetack works
Not in this heat it doesn't!
Same same a few weeks ago - absolutely nothing broken but it just won't clip back in and hold :mad: . Saving the glue until the car's been in to get the door leak problem fixed (ie. door cards removed!)
:confused: Mine's Blutacked in. Maybe my blutacks more industrial than yours i.e. it's got more imbedded substances in it after all these years...
It was either that or try to hot glue or epoxy something "tabby" to it.
It hasn't let go yet, though I haven't had any passengers in the past week or so.
Guess I'll have to experiment with slamming it tomorrow.
J.
