Octavia 2 does not operate optimally at operating temperature
Octavia 2FL - 1.2 TSI. The main feature of this problem is that the cold engine works normally. But when it reaches operating temperature, it goes into a safety mode that limits power and rpm, idling is normal and there is no jerky acceleration...
By some logic, could the cause be a temperature sensor or a MAP sensor?
One more time: the error always appears and only when operating temperature is reached (the coolant temperature indicator on the meter normally shows 90°C, but it could also be one of the causes, even though it shows a normal temperature)
The tester shows the following:
P017200 fuel trim bank1 system too rich
P119A00 Fuel Pressure Sensor - Malfunction
P008700 Fuel Rail/ System Pressure - Too Low
Could anyone help?
Go to this page on the Ross Tech site and put in each of your codes in turn where I have alredy entered your first code, and then click on the adjacent magifying glass symbol to start the search. It will give information on the code and bring up posts from other users with same problem.
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Thanks for the answer, pikpilot. The error has been fixed. The cause was in the high-pressure pump assembly, which did not receive the correct data from the computer. The culprit was the solenoid valve. When I disconnected the connector and cleaned the contacts, unscrewed the nut on the valve and put everything back together... the octi has been working without problems for the fifth day. Maybe this answer of mine will come in handy for someone else someday 🙂
