Memory seat
Hello,
On my 3rd Octavia estate, now have a 64 plate L&K estate.
I cannot get the driver's seat to keep position settings. The adjusters all work, the heater works, but it will not store them on the buttons.
I have followed the instructions in the manual, but still no luck.
My wife and I have very different seat positions, so it is a pain having to manually adjust each time.
I have chaged the thermal fuse but no change.
Is there a back up battery somewhere that I have missed?
Wichtig Control unit is installed?
Control unit? Not a clue. Has the 3 adjusters on the side with the memory buttons above (SET, 1, 2, 3), heated seats controlled from centre console.
Do you have personalisation eneabled?
I have been through the menus, will take another look later.
Yeah, my first instict would be to check the settings are all enabled. I'm not sure about the PFL, but my vRS recognises my key and tells me when I've selected a different user. Our BMW will tell you in the dash which user is selected when you press the memory selection buttons.
I'll have a look when I do the school run in a bit! I do remember something about seats, thought I selected it but possibly not.
I try and use both keys equally as well.
The manual doesn't say you need to have the option for each key to be different to set the positions up
Also, it won't let me turn that option on!
If the car is not remembering the seat setting, it will require a reset.
Here's how to turn the memory seat on:
1) Pull the seat all the way forward
2) Tilt the seat all the way forward
3) Tilt the seatback all the way forward
This should reset and then you will be able to set the memory.
Thank You! Just tried it and it is working 😁
