Firmware Request MST2_EU_SK_ZR_P0369T (SmartLink / FEC Patch)
Hello!
I am looking for a direct SD card patch (FEC ALL / CID OFF) to unlock Smartlink and Carplay on my Skoda Bolero unit.
Here are the exact specs of my unit:
SW Train: MST2_EU_SK_ZR_P0369T
MU Version: 0369
Part number: 5Q0035819B
Hardware: H30
It is a Technisat unit without navigation (no NAV button, single SD slot).
I've already tried enabling Developer Mode via VCDS to use the MIB2 Toolbox, but I keep getting the "Request out of range" error in adaptations on this specific firmware. Therefore, I need a direct patch that I can run via the "Software Update" menu from an SD card.
Does anyone have a working link to a prepatched firmware, or a matching cpu/metainfo2.txt package for this exact SW train?
Thank you in advance for your help!
Dont Work, you need direct contact with emmc and QNX
Developer Unlock with Vcds you have Login with S12345
Edited by Cairus
Moreover, your unit does NOT support Smartlink, you need to have it replaced.
Thanks for the answer.
Regarding this Youtube video (eMMC method with QNX access). Can I follow that specific tutorial for my unit? Is there anything that differs for my 5Q0035819B version softwarewise?
I fix mobile phones, so I have microsoldering equipment and I am confident with the hardware part. I am willing to take the risk of bricking the unit, because if it fails, I will just buy a new unit anyway.
My main question is: Do I really have to crossupdate to firmware 0480 during this eMMC process like they do in the video? Or can I stay on my current 0369 firmware and just patch the filesystem within QNX to enable developer mode/SmartLink?
If I need any specific files or modified dump for this exact 819B unit, please let me know. Thank you!
As pab told, replace unit
My answer was generally referring to units with only one SD slot.
I actually have a unit on order for a test of AA and Apple CarPlay.
Edited by Cairus
Okay, which unit would you recommend? I only want smartlink for carplay, no navigation, cameras etc is necessary. I couldnt find the unit in glowbox, is it located under the display? What unit Will fit?
Swapping USB port is necessary?
