Constant DPF regen
Hi!
Octavia vRS TDI 2015 - For a while I've been experiencing constant DPF regens - the idle tick over constantly sits at 1K with the radiator fans running for a while after the ignition is turned off.
I drive motorway miles daily so it's not a symptom of short trips although on longer 2 trip ~2hrs the Particle Filter warning will appear but clears after ignition reset. I've noticed the regens are having a massive impact on fuel economy (only managing ~350 miles on a full tank when previously I could get around 400-420) as well as oil consumption.
I've had a local garage take a look and apparently found no fault and added a DPF additive to the fuel and told me to blast the car down the motorway - I interpret that as they couldn't be arsed to investigate it as they didn't even charge me...
Has anyone experienced a similar issue? I feel I'll need to point the garage at the potential causes as they're not going to find it on their own it seems...
Thanks!
Rather relevant is how many miles on the car. Have you not had a reading of the ash / oil ash content?
Mileage is ~132k and the garage reported the ash level to be around 60%.
