Am I mad to think about buying a 24 year old Skoda Fabia?
I have been looking around for a basic cheap run around - automatic - but witout much success. There is a 2002 Fabia 1.4 16V Classic 5dr forr sale near me. £2700 (which is overpriced I feel) with 66500 miles on the clock and it says 1 previious keeper. Am I mad to be considering a 24 year old car? I just missed out on a 2013 fabia though I was worried about the DSG gearbox.
I used to have sometime ago a 2003 Skoda fabia and loved it. But I'm worried about taking on such a old car.
I might add I know next to nothing about cars!
Have you checked the MOT history?
Thanks. AG Falco
Thanks. AG Falco
Yes it seems to have passed every MOT until Jan 2024. It makes me feel like it's been well cared for.
Where it Failed on:
Do not drive until repaired (dangerous defects):
  • Nearside Front Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
  • Offside Front Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
Monitor and repair if necessary (advisories):
  • Nearside Front Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
  • Offside Front Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Failed Jan 25 on:
  • Nearside Front Tyre has a tear, caused by separation or partial failure of its structure excessively worn showing metal cords (5.2.3 (d) (ii))
  • Offside Front Lower Suspension arm pin or bush likely to become detached has excessive play in rear bush (5.3.4 (a) (ii))
Repair immediately (major defects):
  • Offside Front Tyre date code illegible or not visible on a tyre fitted to a front steered axle of a bus or coach tyre showing metal cords excessively worn (5.2.3 (n) (ii))
  • Nearside Front Lower Suspension arm pin or bush excessively worn has excessive play in rear bushes (5.3.4 (a) (i))
  • Nearside Front Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
  • Offside Front Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
It failed in Apr this year with:
  • Front Brake disc significantly and obviously worn Both Sides (1.1.14 (a) (i))
  • Offside Front Outer Drive shaft joint constant velocity boot split or insecure, no longer prevents the ingress of dirt (6.1.7 (g) (ii))
  • Offside Rear Tyre slightly damaged/cracking or perishing (5.2.3 (d) (ii))
  • Rear Registration plate deteriorated but not likely to be misread (0.1 (b))
  • Oil leak, but not excessive (8.4.1 (a) (i))
But has since passed.
1 hour ago, Mory said:
it says 1 previous keeper.
When did the second owner buy the car?
2023?
Any service history/ invoices?
Thanks. AG Falco
2023?
Thanks. AG Falco
Jan 2016 apparantly.
I'm not sure as yet if there is a service history/invoices.
bought my son mk1 55 plate 1.2htp to learn to drive in. Had only 60k on clock and had been well looked after with minimal rust etc. He still has it and apart from a clutch exhaust flexi and a couple of ball joints been very good. Cost £1600 which was above book price but low mileage and no rust thought it was worth it. Had 1 owner for years and then the previous owner before him.
The one your looking at £2700 I agree its a bit overpriced but MOT history seems fair with no major problems. Check that what it failed on have actually been repaired properly and not just covered up etc. It may need new suspension bushes etc due to its age and historical tyre wear.
Alasdair
  • 3 months later...
Those failures are common failures.
Moving parts on cars wear out so its expected at some point although I'm surprised at the very low mileage and several failures for the bushes and arms.
It is very poor road conditions in the area of the car? Country lanes poorly maintained etc?
