Haldex versions
Hi everyone
So my mk3 Tour de France has had its Haldex eat itself - I’m struggling to locate a replacement. If I go for an updated part number or superseded version - how new can I go before it won’t work or will any newer versions work. My initial research says any Will work you just do A Haldex relearn but I’m skeptical with all the ai derived horseapples on the internet now.
For reference I have a gen 5 Haldex with the OCQ 907 554d could I use a 907 554j for example?
Thanks legends
  • 4 months later...
Hi, I've got the same problem with my 2014 MK3 Tour De France.
And yes, it is proving very difficult to find a replacement. Although I have been quoted £7500 to repair 🤯🤯🤯
My garage said cheaper/easier to get a 'new' axle with haldex already fitted and swap it over.
Did you find a solution to the problem?
Yea, I got one from an s3 Audi after a few months looking around. part nos matched
Ahhh. I did wonder if it would be compatible if it was from a different car. But as long as the numbers match I suppose it should be fine.
Cheers
Still hoping to find an axle with haldex fitted for easier/cheaper fitting but thank you for the very useful info 👍
Did you have any luck? I know a guy in Wales I’m going to get to rebuild mine (2015 Scout TDI). I’m not very near Wales though, but I trust him.
No joy as yet 🤷🏻‍♂️
A couple of ideas to try but they are longshots.
Is your guy in Wales rebuilding yours or replacing it?
Without meaning to sound rude, how much is he charging?
Rebuilding. Don’t know the cost but he’s not greedy.
Recently Browsing 1
