Lego pushed between window and door
Hello All,
So my youngest son decided to push a small flat piece of Lego between the window and door.
I can just about see it, but have no idea how to get it out. I’ve not operated the window as I think will drag the Lego inside the door.
Any ideas or hacks on how I can remove it without taking the trim off the door?
Many thanks!
How about trying a straight length of stiff wire, bent into a right-angle at the end, to hook under the piece and lift it enough to pull it out?
Recently Browsing 1
