Odd loss of power / 1.0TSI (DLAA) 81kW / 90 000km
Hi everyone,
For about the past month, I've been experiencing an intermittent and unexplained loss of power on my car. There are no warning lights, no check engine light, and no fault codes stored. The car simply feels down on power, almost as if it's lost around 10–20 kW. When it's running normally, the turbo builds boost early and the car pulls well. During these episodes, however, boost seems to come in much later at higher RPM, making the car feel sluggish. I've also noticed a significant increase in fuel consumption.
Under normal conditions, I average around 4.7–5.3 L/100 km, but when the problem occurs, it rises to about 6.0 L.
So far I've found and repaired a broken EVAP hose, and the engine ECU has also been updated with the latest software, but neither has solved the issue. I also checked intake valves for carbon buildup - they are clean.
The strange part is that the problem is completely intermittent. It doesn't seem to depend on outside temperature or driving conditions. For example, during a recent road trip, the car drove normally for about 200 km, then suddenly became noticeably down on power. After driving for a while longer, it returned to normal on its own. Today it became sluggish again.
Has anyone experienced something similar or have any ideas what could cause this, especially when there are no fault codes?
What country are you in? Is the ECU Software update because of a TPI / TSB from Skoda? What ambient temperatures are you talking about where you are? When were the spark plugs inspected or replaced? Is there a fresh clean air filter fitted? What is the fuel used, E5 or E10?
Edited by Evolution13
I'm in Slovakia.
The ECU software update was performed by the dealer, but I'm not sure if it was related to a specific TPI/TSB.
Ambient temperatures have ranged from around 15°C up to 40°C, and the issue has occurred in both cool and hot weather.
The spark plugs and air filter were both replaced about two weeks ago, and I always use E10 fuel.
Maybe try some E5. Lots of rubbish fuel about since the 'Military Action' in Iran. Everyone will be looking for Software Updates now. I Love 'Skoda Secret Service Service Campaigns'.
Thanks! That's actually my next step. I'll run a few tanks of E5 and see if it makes any difference. Hopefully it's something as simple as poor fuel quality.
You may have a sticking butterfly valve in the throttle body even though unlikely based on your posts, I had this in a 2000 Bora at ~ 60K miles due to carbon build up in the throttle body from the EGR which was causing all sorts of problems, I just removed the air filter and sprayed WD40 around the butterfly circumference (engine Off) a few times and problems disappeared.
Update: Since I've been using E5 fuel no issues whatsoever. Thanks for advice everyone.
Its amazing how sensitive some of these engines seem to be when changing from 95 octane to 98 octane apparently cures the problem, mind you, in Spain there are at least 3 different choices of petrol, around here, its practically all E10 (95 octane) and you will have to travel to get E5.
@Johngerard You could use an Octane Booster with 95 Ron E10 bought in the RoI. In the UK the E5 is sold as 97 Ron Minimum or 88 Ron minimum. There has not been 98 Ron Minimum sold in the UK for over a decade.(VW FAQ site has never recognised that as being the case.) Not all E5 in the UK contains Ethanol. It is Regions / Depots & Distribution dependent.
