LED daytime running light (DRL) failing/flickering - 2022 Fabia
Hello folks,
My partner has a 2022 Fabia with LED headlights. These incorporate LED daytime running lights. In the last couple of months, the nearside DRL has been failing. The first indication of a problem was a dashboard warning saying it needed checking - though when we looked, it appeared to be working fine. In the following days and weeks this progressed, so that the error would pop up with increasing frequency and more often, the light itself would be out when checked. Today, the dashboard warning is almost always present, and the light is almost always off. I notice though that sometimes the light still flickers - I think more commonly after start-up though it's hard to be sure as clearly, once driving it's hard to see your DRL! I'll also mention something I feel 99.99% certain is unrelated, but just in case - the first time the error popped up, I'd just replaced the cabin air filter. I can't think of any possible reason why that could be connected, but... just for completeness!
I've been told that the only solution to a failed DRL is to replace the entire headlight unit at a cost well north of £500 - not money my partner has lying around spare. I find it hugely frustrating - in fact outrageous - that manufacturers are allowed to build cars in such a way that something as previously simple as a failed bulb now necessitates vast repair costs and an absurd level of waste - the rest of the headlight is completely fine, but has to go to landfill because one minor component has failed. Economically and environmentally, it's pretty disgraceful.
I wondered if this is an issue anyone else has experienced, and whether there is any other course of action available to fix, short of binning it and taking out a second mortgage to buy a headlight! Any and all thoughts and guidance would be much appreciated.
As an aside, other than this issue it's a great car and my missus loves it. She drives a lot for work and it's done 62k miles in the four years we've had it; she's planning to keep it for at least a couple more, but this costly glitch is kinda tedious - especially as there's clearly another DRL on the other side which we're now viewing with trepidation!
Thanks again, and best wishes to all.
Steve
I think that it is possible to repair only part of the entire headlight, that is, the DRL part.
Ask Dr. Google.
My 2024 Fabia Mk4 has non-adaptive (ie. non-matrix) LED headlamps, an example of which is shown in the attached image and the DRL comprises a 'strip' of LEDs along the headlamp's lower edge.
As DRLs are continuously illuminated while a car is being driven, using (normally!) long-lasting LEDs for them, instead of bulbs, makes some sense. Unfortunately, LED DRLs rapidly became a design 'fashion statement' and integrating them into a headlamp-unit means that LED DRL failure often means that the whole (expensive) headlamp must be replaced.
This advert suggests that the control-unit for a Fabia Mk4's LED DRL and LED turn-signal may be replaceable
https://xenonpertutti.com/gb/centraline-xenon-originali/led-module-b342998-e-skoda-fabia-iv-left-headlight-drl-and-turn-signal-replacement-control-unit.html
but, if the DRL strip itself had failed, a replacement headlamp-unit would almost certainly be required.
A Skoda dealer should be able to confirm whether or not repair is possible.
Repairs to individual components within an integrated LED headlight are, where possible, carried out by independent technicians; at least, that is the case in Serbia.
My recommendation to everyone is to use coding to disable the DRLs whenever the low or high beams are on.
don't know if it's still relevant to you, but I have some info you might consider useful.
So the first question is whether your Fabia has LED "Low" or Led "High" headlights.
This is the standard "Low" headlight:
This is the pay-extra "High" headlight with adaptive functions:
If you have the "High" headlight, the DRL/indicator LED module can be replaced. I've actually taken apart a "High" spec headlight some time ago. Here's what the module looks like:
Bear in mind that you have to remove the headlight unit from the car to replace the DRL module. This also means that you have to remove the front bumper. So it's not something I'd recommend doing yourself if you're not experienced.
One more thing is that there was some other PCB buried deep within the headlight housing (i.e. not removable) which has two LEDs (one orange and one white) and was positioned such that the LEDs shine into the DRL/indicator plastic strip. Not sure why this exists in the addition to the module shown above.
If you have the "Low" headlights, then I'm not sure if the DRL module is replaceable, I'd say no given the fact how the individual LEDs are positioned across the headlight unit. You can double check though if you have a parts catalogue at hand (i.e. https://www.partslink24.com/en/index.html, note that there's an access fee).
Edited by gogo110
I see now this is the same component as linked by DerekU. It is not a control unit (the advert has it wrong). You can see the individual Light Emitting Diodes on the circuit board. The control unit for the entire headlight is the grey metallic thing on the first image I've posted.
12 hours ago, gogo110 said:
Hi, thanks very much for taking the time to explain so thoroughly. I'm afraid we have the standard 'low' design, so it appears we are doomed!
It's so frustrating. Today the light has been working about 50% of the time - other days, it's off all the time. I think it may be possessed. Whatever the case there's just no way it should cost a family holiday (Skoda have quoted £880 or thereabouts) to fix a defective light on an ordinary small car. It's an absolute disgrace and in my view shows Skoda's contempt for their customers - nothing about this needed to be this way, it's purely the manufacturer's intentional choice.
Anyway, at least I now know I'm not missing a trick - we really are that screwed! Thanks again for your thoughtful and comprehensive reply, it's much appreciated.
It won't make you any happier, but the £880 price you've been quoted by Skoda for fixing the problem (that presumably would involve replacing the existing defective headlamp) is - as the 2024 CAT article (link below) highlights - not that unusual
https://www.catmag.co.uk/features/led-lighting-replacement-cost
and, In 2022 when I was considering buying a Hyundai i20N, I was reliably informed that the cost of a single 'full LED' headlamp for that model was around £1400.
In 2015 I bought a new motorhome based on a Fiat-Ducato chassis. Its headlamps were the 'all halogen bulb' type, but Fiat also offered an LED equivalent that was MUCH more expensive. Within about a year, much cheaper 'aftermarket' headlamps for the bulb-type light became available, but, if an original LED headlamp failed or became damaged, it was (and still is) not possible to buy a less expensive 'copy'. Current Ducatos still have halogen bulbs for the main and dipped beam, but may or may not have a LED DRL. A 'copy' headlamp with no DRL can cost well under £200; a 'copy light with LED DRL (but no LED driver) can cost about £275; but an OE headlamp with LED DRL + LED driver is priced around £560.
The CAT article says
WhatCar?’s advice was very clear: “If you’re going to keep your car for many years or are buying second hand, we’d recommend avoiding models and trim levels that have sealed headlight units.”
but this has become increasingly difficult to do as car manufacturers drop replaceable-bulb headlamps from the specification of their products irrespective of the trim range.
TBH the issue sounds more like an intermittent connection or a dry solder joint either externally or internally... Presumably you've checked connectors and fuses etc as the fuse box is closed to the pollen filter you replaced so could have been disturbed?
Otherwise a second hand headlight would likely be massively cheaper...
On a RHD Fabia Mk4 the fuse-box is to the right of the steering-wheel, while the pollen-filter is behind the large glove-box that is on the opposite side of the car's dashboard. So replacing the pollen-filter should have no effect on wiring/fuses.
Ah... Ok. Thought it was the same as the bigger cars where some fuses are accessed by pulling the glovebox down on a RHD car.
Presumably you've checked connectors the headlight itself and on the back of the dashboard switch?
So I've managed to dig out the Fabia service manual I've downloaded back when Erwin for regular citizens was still a thing.
Headlight "Low":
Headlight "High":
So the "Low" headlight definitely has no replaceable DRL LED modules or Control units of any sort.
But what is also interesting is that for the "High" headlight DRL LED module it says "Part of the headlight, not a spare part". And indeed the module itself has no label with a VW part number. So I'm guessing that if this thing went bad then an official Skoda garage wouldn't want to replace it since they cannot order the thing without ordering the whole headlight. So much for repairability...
Just to depress you further but I understand that a failed drl is a MOT failure in UK - sorry!
On on vehicles 1st registered in the UK from the 1st March 2018.
The UK MOT-test rules regarding DRLs are as shown in the attachment below.
In @SteveFab partner's case, as the car is a 2022 Fabia Mk4, it's DRLs will be inspected during a MOT-test and, if either of its DRLs is found to be inoperative, that will be classed as a Major defect.
Could be worth asking Skoda if they will contribute to the cost via a goodwill gesture as the part hasn't lasted as long as it should have? Do you have a main dealer service history?
