Head Gasket?
Hi All,
AUQ 130k miles
Has been losing coolant and white smoke out of exhaust for a while
Replaced some coolant pipework and thermostat which stopped it for the most part where it appeared to be leaking
Notice a slight shimmering film on top of coolant reservoir before driving
Drove for several hours and coolant red light on dash came on with alarm
As close to home (and temperature not going up) drove a mile or two to house and parked up
Left overnight and checked coolant this morning and its changed colour to a murky brown (from darkish pink)
The level of coolant it above minimum so not sure why the alarm went off as level and temperature seemed fine.
One thing I noticed when opening expansion tank was a pop and hiss (escape of gas?) which hasnt happend before especially after leaving over 12 hours.
Is this likely to be a head gasket gone or an oil cooler letting oil into the coolant or something else?
no white may on dipstick or under oil filler cap (does use a bit of oil though as need to keep topping up)
Any advise appreciated,
Could be the prongs in the expansion tank are dirty hence the alarm. Try giving them a scrape with a screw driver and top up to max and monitor it. If theres still white smoke its most likely HG especially with release of pressure and brown coolant. You could run the car stationary without expansion cap and look for bubbles in tank or oil on top.
Alasdair
