Air Quality Sensor testing
The air quality sensor (1K0907659) appears to have failed on our 2013 Yeti. In VCDS it is throwing the DTC 9481988 - Air Quality Sensor B10AF 04 [008] - Internal System Fault
The price of a replacement OEM part was £140 plus the hassle of a 1 hour round trip to collect it from the dealer. So given the price of £20 for a Chinese version, I have tried that. However it is giving me a different fault 9479189 - Signal Line for Air Quality Sensor B10A4 15 [008] - Open or Short to Plus Upon testing this Chinese part on a bench using a PSU set to 12V 0.1A, with pin 1 (12V), pin 2 GND, then I'm seeing 10.5V on pin 3 for a few seconds and then it drops to 9.5V for the remaining time. It is drawing 45mA and then 0mA respectively. I think it is simply a fault part but curious to know how others have got on with the Chinese part? Has anybody got voltage & current values for a known good sensor? The old failed sensor I have has 0.5V on pin 3 and is drawing about 10mA constantly.
Edited by rabbituk
I believe there are two different styles of sensor around this time, one with an output that is at a low voltage when measured with a meter, the other with an output that sits high as measured with a multimeter. You may have the wrong type. The latter, later type is the LIN-based one, I think, but would need your VIN to research which type your car should have.
See G65 sensor no signal - Skoda Octavia Mk3 (2013 - 2020) - BRISKODA
I'll message you to ask for the VIN. Is there no letter suffix after the core 1K0907659 part number you mentioned.?
Those suffix letters can identify/disambiguate completely incompatible versions.
Edited by Breezy_Pete
Unfortunately, there is no postfix to the part number. Other writing on the older failed unit is 'PAG', the end opposite the sense intake has 'IND 12' and 'II 232/32'. Presumably the latter being a part manufacture date.
That turns out to be consistent with the parts catalogue. For your VIN, the number you quoted is complete without any suffix.
It has been superseded by 5K0 907 659, but that's not the key point.
Circuit diagrams for your date of manufacture (28.08.13) show no sign of the output being a LIN bus signal.
Searching through Yeti circuit diagrams that I have, as far as mid-2016 still don't show a LIN output version air quality sensor, so I suspect that this model never changed over, unlike in that thread I linked above.
I suspect the item you've bought suits LIN-based air quality sensor systems instead.
Try to match your exact part number, or the superseding one above, and ignore any that have suffixes after the main 9 characters.
Try buying a genuine one from TPS, they usually deliver as well when you set up an account.
I don't have a 'scope that I can use to test this part with however I don't see much movement in the value which I would likely see if the value was oscillating over time. Presumably we can't know if the superseded part was an improvement or simply a change of sub manufacturer.
The eBay advert I purchased it from specifically listed my car model as well as the aforementioned OE part number so I thought it would be the correct type. For a non-safety critical part like this I was just trying to see if I could save a little money.
There appears to be a lot of confusion with eBay sellers regarding this part and nobody selling a new part appears to have a clue as to the version that they are selling despite all claiming to be equivalent to OE 1K0907659. I ordered the Febi version and it too is LIN as I've now managed to find my logic analyzer and can see the PWM and LIN signals distinctly (@Breezy_Pete your assumption appears to be correct). The LIN version appears to draw about 60~mA where as the PWM version draws 10mA. This makes sense given the higher data rate of LIN part. My original sensor appears to send roughly 80ms LOW, 80ms HIGH, 20ms LOW, 60ms HIGH in that order. LIN is significantly faster. The failure mode of my original sensor is that it unfortunately stops communicating after 45s every time it is powered on.
I wonder if the later Yeti's used the LIN part, mine is a preface lift? Presumably only the clilmatronic control panel would need to be updated to accommodate that.
Good to have confirmation of the comms difference. 🙂
As I mentioned a couple of posts back, I couldn't find any Yeti diagrams showing the LIN version of the sensor.
I know that you've said that 5K0907659 supersedes 1K0907659 but is it definitely compatible? i.e. Do we know that the 5K0907659 part is definitely not LIN bus based? On the catcar.info, if I look at the diagram for the 2013 Yeti, it only lists the 1K0907659 part. However if I look at the 2014 year and onwards it lists 1K0907659 with 5K0907659 in brackets.
I'm just surprised that so many sellers on eBay have the wrong part advertised and this makes me suspect that they are only partly wrong and it works for some years but not others.
I believe that a supersession automatically implies compatibility, but I guess I could try to see which other vehicles use the newer part and see that their circuits don't mark up the signal line as 'LIN'.
Remind me this evening!
I would be interested to hear from anybody that has successfully fitted a 5K0907659 air quality sensor to their pre facelift Skoda Yeti. Currently I don't see how it can work without alterations to the Climatronic control panel. As previously mentioned, the news sensors appear to speak LIN whereas the old ones are PWM. Unless the sensor is multilingual, the protocol used on the sense pin (pin 3) is going to be different and not be understood by an unaltered climatronic control panel.
I have attached a trace of both old sensor 1K0907659 and a new sensor from Febi part 194829 but based on the 5K0907659. I don't believe that the replacement 5K0907659 OEM sensor from Skoda will be any different to the Febi part and I'll have the same problem.
Old sensor wave form:
New sensor wave form:
Edited by rabbituk
I have now purchased a 5K0 part albeit second hand and it actually does output the desired PWM signal and has subsequently caused the fault to be cleared. So the issue was that Febi and the other seller were falsely advertising their part as compatible with 5K0 907659/1K0 907659. They are not. I am quite disappointed with Febi as I used to consider them a trustworth company.
Thanks to @Breezy_Pete for persauding me to try the OEM part.
You might consider linking Febi to this thread as helpful feedback for them?
2013 model Yeti (built 14th of june 2012)
Thanks for this thread. Got an AIC 58203 as replacement for 1K0 607 659, didn't work: 'B10A4 11 [00001001] - Short to Ground'
When testing with an oscilloscope after having removed it again it simply did nothing on the signal line. Unclear if it got damaged when connected to the system or if it was dead from the beginning and might work when OK.
Bought a used sensor from ebay and it was (almost as expected) as dead as the original sensor ('B10AF 04 [00001000] - Internal System Fault').
Got a Hella sensor 6PX 012.684-001 as replacement, it showed a (rather small) PWM signal and works.
(There's a lot of other versions of 6PX 012.684- sensors- the 001 at the end is important)
