P200200 Particulate Trap Bank 1 Efficiency Below Threshold on 2.0TDI CUNA 184HP Scout.
Hi all,
I'm getting intermittent P200200 fault codes and occasional CEL that resets with Torque or OBDEleven apps for a couple of regens.
From what I can tell online, this indicates a EGR blockage/fault issue rather than DPF itself.
VAG DPF app shows that measured soot climbs faster than calculated soot in the DPF - the measured often going negative after a proper DPF regen.
Soot mass is <60% according to the app, so seems like DPF doesn't imminently need work.
Car is at ~110k miles and no plans to change in the next couple of years - the sensible answer is to keep it as long as it's a reliable workhorse.
What I'm pondering over is how much money to sink into resolution.
New EGR valve/cooler?
Cleaned EGR/cooler (s this a thing?)
New EGR and new/cleaned DPF.
I'm happy to spend money on what actually needs fixing, but I have trust issues with unnecessary fixes, and snake-oil "DPF cleaning" salesmen, and so on...
Does anyone have any experience, thoughts or wisdom?
I use a small local garage for general servicing, but not a specialist - so any recommendations near Nottingham are also welcome.
BW,
Jono
