Very wet carpets
Hi, new here.
Skoda Yeti 2014 2.0 diesel (170bhp) 4wd. In the last few days I have noticed small amounts of water on top of the rubber floor mats, front and rear O/S. It was noticed first in the rear footwell but yesterday it was very evident in the drivers footwell. Warm fine day, so used the air con and noticed the water amount had increased. When we got home I removed the rubber mats and the carpets were extremely wet. We had to place old towels on the floor, stand on them (water rising visibly under pressure), wring out towels (soaking wet) and repeat many times until too tired to continue - will resume today.
Thoughts were, blocked drainage under windscreen (will check) but more likely air con drainage issue, particularly as using the air con made the problem noticeably worse. I drove the car into the garage and turned the air con on for 3 or 4 minutes - no sign of any water dripping onto the floor.
Recent events that may be relevant:- had an air con check at Kwik Fit several weeks ago and we noticed the mechanic jump, exclaim, accompanied by loud hiss of escaping gas. they said the pressure was OK and we left but immediately noticed the air con was noisy. Returned and they reluctantly agreed all wasn't right and re-gassed free of charge. Could the drain tube have been damaged? Also, a couple of weeks ago the Garage removed the engine tray to fix a leaking oil filter, could they have kinked/trapped the air con drain tube?
Sorry it's a long post, will appreciate any advice.
Recently Browsing 2
