Vibration noise between 2k rpm-3k rpm
Hi guys, I recently purchased a Skoda octavia VRS 2017/67 plate face-lift model, and I noticed upon hard acceleration there is a vibration noise coming from NSF side/passenger front more towards the middle, this happens in every gear when the revs are between 2000 rpm and 3000 rpm. Whilst I was travelling 40mph, I pressed the clutch pedal in and revved the car and noticed the vibration noise happened again between those revs.
The dealer i bought it from said it was a boost pipe leak but I know for a fact if it was that, the vehicle would be under power/limp mode and engine light would be on. I even did a smoke test to see if any pipe for leaking to which they weren't.
I asked a few mechanic friends and one of them mentioned a borne speaker which sits under the scuttle panel and apparently they were common to vibrate under hard acceleration. I removed the speaker and its still vibrating.
Im thinking it could be down to the gearbox and if it is I am going to return the car back within the 30 day period and get my money back but before I do that doea anyone know what it could be because its a very nice specced car and dont paticularly want to give it back if its a fix I can do myself.
I have a similar thing around 2500rpm in my vRS, but only under load (uphill or accelerating to enter motorway), and only very occasionally, i.e. not easy to reproduce at will. I suspect something is loose around the engine, several possibilities, including but not limited to a cracked piston ring, a cracked piston skirt around its wrist pin, or some balancer shaft issue. If it is any consolation, I have done 60k+ miles since I noticed the issue, though for me, it happens quite rarely.
The engine drinks about a 250ml glass of oil per 1k miles, in line with my previous 1.9TDI Octavia which did have a cracked piston ring but otherwise engine was bulletproof. Fuel consumption and performance are both very good, and I intend to keep my vRS until the engine dies or until it meets some other end of life event, as any manual gearbox diesel car replacement will have 35% less power.
Recently Browsing 1
