SD cards and the Amundsen infotainment system.
I guess this has been asked and answered dozens of times but I've trawled and found nothing recent.
A few problems.
I'm really struggling to update the Nav system.
  1. I only have access to a Mac, on OS 26 Tahoe.
  2. Can I use a new card that IS NOT a Skoda original, or must I stick with what I have?
  3. The Mac seems to insist on writing extra files to the SD card and messing up the install.
  4. Can I simply 'unhide' and delete these files, or is something else needed?
Naturally this has all caught me out with 2 days to go before a big trip - when a Satnag would be very useful ...........
The Skoda Update Portal seems to say any SDS card will do - but it won't ......... unless I've missed something fundamental.
HELP!!
If you have Amundsen MIB2, you will need to use an official SD card. It may pay to get a 32gb replacement card if your original one is only 16gb.
Edited by Warrior193
correction
Patch Unit and you can use every SD Card
Please explain. I'm O-L-D. 😁😁
What is 'Patch Unit'?
If using anything other than a Skoda original/coded SD card, is it possible to use a card larger than 32Gb? (I have several ......)
Yes
Amundsen maps need to be on an SD card that had the correct ID so it is (or looks like) a genuine Skoda card (or it appears you can hack the Amundsen to accept maps any card) - I use a 32GB genuine card I got off eBay.
Amundsen music can be on any SD card - I use a 256GB SD card.
The CID in ASCII simple "MIBSTD"
OK, forgive the ignorance.
What do I need to do/add to an ordinary SD card to make it work as the Satnav data storage?
(that's if it can be done .... )
Picture of actual Software train.
Press Long Menü, Service Menü Open, Then Software Update, then picture
Edited by Cairus
Thanks.
I can get the first three stages, no problem.
When I get to Software Update, it offers the current, then a second choice. I am nervous of the 'poke and hope' approach, so where do I go next and what card should be in the SD (1?) slot?
Can I also ask what you mean by ''then picture"?
You have to Share the Picture Here which Software train is installed
Recently Browsing 1
