Fabia 2024 door plastic
Hey my door handle plastic is fading on both sides, any one has any idea if its replaceable and where to buy new?
Fabia mk4 2024
Have you asked a Skoda Dealership in Israel for the cost of new replacement parts? If the new ones faded because of Climate / Environment are new ones not just going to go the same way? A Skoda Fundamental Design, Engineering, manufacturing, material fault and a product not suitable for your region. TELL THEM!.
They do not take any responsibility for plastic compoments i have had my fair share of converstations with them.
Is the Skoda CZ or Skoda Israel rather than just staff at a Dealership!
Skoda is imported here, the official importer of VAG group.
They do not care about plastic
Daughter used Gtechniq C4 Permanent Trim Restorer on her old peugeot 205gti and it cured the faded plastic trim. been on for about a year and still looks good.
Alasdair
I understand that a Skoda Fabia Mk4 bought new in Israel will have a 2-year warranty and (presumably) that warranty's terms and conditions will be similar to those of the UK warranty that includes this exclusion.
Damage caused by industrial pollution, climate, external heat, chemicals or mechanical force.
It seems much more likely (to me) that 'fading' of the black trim surrounding the window switches will have resulted from a fault in the trim's plastic material rather than from Israel's climate, but Yogev's Skoda dealership might argue the opposite and not support an under-warranty replacement.
Having looked, not too closely, at the plastic trim around my 2024 Fabia's switches, I think the trim+switches should not be too difficult to remove. (That's just based on there being a small slot in the lower edge of the front part of the trim behind the door handle.) Realistically, a new replacement trim will only be available from Skoda and the chances are small of finding a secondhand trim from a smashed-up Fabia Mk4.
This link relates to black trim restorers and may be of interest
https://www.carmagazine.co.uk/car-advice/maintenance/the-best-black-trim-restorer-to-freshen-up-tired-plastics/
As Evolution3 mentioned earlier, it would be worth Yogev asking a Skoda dealership what the cost of a new trim would be (It would almost certainly need to be ordered). If a new trim is fairly inexpensive (and the 'fading' really annoys Yogev), a replacement could be fitted: or, if the cost is high, Yogev could try a trim restorer - though they can be pricey.
