Power steering light illuminted on dash, it comes and goes
Ok, so yesterday whilst returning home said light came on, it was amber coloured, it eventually went, but returned sparodically.
Is there a power steering oil top -up point somewheer or is it likely to be something else,
I cannot find any references on here.
The car has covered 109k and is a deisel 140
Thanks in advance
Tony S
Think the yeti uses electromechanic steering so no fluid. Could be a dodgy wheel sensor, steering angle sensor or as simple as low battery. Did the ESP come on as well? best option is to get it scanned with vcds to see if there are any stored codes.
Alasdair
So, had the battery on slow charge for 18-19 hours, Disconnected and fired the car up all warning lights cleared, I have to go out latr, about a 25 mile trip so that should give me an idea if it was just battery base, also a chum is coming round later this morning torun a vcds trial.
Will keep you all updated!
The prob appears to be the front offside abs sensor, of which i have one in my garage, just need to find and fit it!
Glad you found the problem. Weird how an ABS/speed sensor can affect steering. I take it it pinged up on vcds. I've managed so far with a cheap copy scanner for just fault codes/resetting but reckon as my cars getting a bit older will finally have to invest.
Alasdair
I should have said that eventually the abs and the traction control lights were also illuminated, found the sensor so today's task!
Edited by Frenchtone
Fitted, a Bosch variety, and a 2 mile run has proved the sensor was the problem!
A little advice if anyone has the same problem, opt for a genuine Bosch piece - 4 or 5 years ago i tried one of the cheap chinese jobs ---- it didn't work,
A friend confirmed their operating characteristics cover a different range, be warned!
