Facelift steering wheel
I've browsed through previous posts regarding this, but can't seem to see if the facelift steering wheel is just a plug and play replacement into the pre facelift.
Ideally I'd like to add paddle shift but I think that's only on MQB platform cars?
Seen a few cheap facelift steering wheels on eBay but usually don't come with airbag. Will my pre facelift airbag fit?
Cheers
As far as I remember it's plug&play. You can add MSFW with paddle shift but it requires coding and MAY require change of steering wheel controller.
Pre-lift airbag will NOT fit, it must be replaced too, as well as the harness located inside the steering wheel.
Ok thanks. Am I right in saying that a MK3 steering wheel with paddles and multi function won't work? My current pre face lift is multi function.
Unortunately, you are right, you need MFSW either from Superb Mk2 or Yeti. I think some from O2 will also work but not sure which ones.
That's what I thought. But the facelift MK2 one with multi function will fit in mine plug and play and the buttons will work?
As far as I remember 0 yes, unless you instal the one with paddles.
