Octavia vrs 21 plate front disc size?
Hi
What size are the octavia vrs brake discs?
Im under the impression the front are 340mm x 30mm and rear 272mm x 10mm?
Is this correct? And for those who have theirs changed have you sticked to genuine or aftermarket parts?
Regarss
1 hour ago, Sp2025 said:
Hi
Regarss
The easiest way is to measure them
Unless it's a hybrid, it should be 340/310. It'll be 340 up front regardless, and the 310 are vented, while the 272 are solid. Easy.
