Retrofit BCM Problems
Hello, I was retrofiting BCM with SW175 to SW0236 on 2016 superb estate. New BCM 5Q0907084CG was codet with dataset from another superb and filter to my Car where I was able to do CP. But because the dataset from another car was not similar I have same issuers. I’m looking for prcoding via Vctool or pr coder dataset via VCP but I’m not able to find something witch would work. Thank you fór your advices.
What problems are you having? Why the replacement? Error log readout?
Replacment due 10color ambient lighting and after replacment reverse Light doesnt work. PLA and camera work only via Car moving backwards(esp signal). Heated front window lights up but after second turn itself off. Midleconsole buttoms (autohold and doorlock) doesnt illuminate orange
Do you have a VAS6154a or b?
I have acces to dealer ODIS, CRACK ODIS, VCDS and VCP.
witch means I should have both of the VAS
Connect the old BCM—it doesn't matter if Component Protection (CP) triggers. Create a backup using the VC tool, connect the new one, transfer the backup using the VC tool, and purchase a stock dataset if necessary. That’s how I would try it.
If it was just about expanding the color range, an update would have sufficed.
