Can anyone help identify these hoses/parts
Hi all, had an intermittent engine warning light with an error code that reference the vacuum pump.
Local garage quoted me near a grand to replace the two hoses shown in the pictures, but that seems insane to me. Can anyone help me identify the parts/hoses so I can order them and replace myself.
To get a quick answer, please tell us which engine and MY your have. It may help... 😉
Thanks for the heads up Bap33!
It’s a Kodiaq 1.5 petrol from 2020 ☺️
oil evapour, gasoline evapour
Hi imart143!
Thanks so much for your help.
Managed to find the oil vapour pipe online (Google told me it was also called a crankcase breather hose), but the gas one is proving a bit more difficult.
Could anyone provide a link to the right replacement or suggest what else it might be called?
@Cgwchris Was that local garage quoting near £1,000 to replace or a Skoda main Dealership? Was that after a Tech or Master tech inspecting the pipes?
Edited by Evolution13
in original, VAG have complete system with valve and its expensive, i had minor leaks and diassemble hoses from engine and this rubber is not bar, but plastic one have few leaks, i used selfvulcanization tape and I wrapped the entire ribbed pipe with it, 2 years ago, and everything is still fine. It's oil-based, this rubber fuel-based one never cracks.
https://www.3m.co.uk/3M/en_GB/p/d/b00011942/
Thanks again for all the help here - first time on a car forum and great to know people are so friendly!
@Evolution13 the quote was from a garage local(ish) to me that someone on a local Facebook group had recommended to someone else. They were great on the phone but it turned out to be a very posh/premium place full of Porsche’s etc. Their quote wasn’t quite £1k to be fair it was £150 diagnostics, £600 plus VAT for parts and labour and then another £80 for ‘retest’. The 2 pics showed the hoses then they sent me another load of advisories about the puncture canister being out of date and replacing the key battery. I wouldn’t care, but I also asked them to check the reverse switch as the car doesn’t seem to realise it’s in reverse, and they want to charge me another £150 to look at that separately!
@imart143 I was thinking something similar. I have a friend who’s extremely handy with cars who could help me change the crankcase hose (found one online for £20 I think) and then just seal the gasoline hose with the tape you suggested (my amateur brain went to a glue gun and gorilla tape but this is probably better 😅).
Any other ideas welcome. If anyone knows if this is the right hose to replace the bigger one in the pic for my peace of mind I’d be very grateful. IMG_6159.jpeg
This pipe you had picture is big one from PCV valve to intake.
Tiny pipe on my pic is one that cracks and only on part where is ribbed, go to your friend to take it of engine, and repair part that have leaks. I uset rubber tape, for me best material, go to 90°C.
New pipe is 170€ in skoda-parts
This is the same as I have on our 1.5 tsi. Just posted about it. Can you let me know part number please and I can investigate options.
