Fabia ECU kit
Greetings to all and 👋
I own a 2003 Skoda fabia 1.4 16v with the BBZ engine manual gearbox
I'm also new to this community,oh and I live in Barbados
I purchased this car 3 years ago, thus is my 2nd fabia, the first being a 2005 model with the said BBZ engine, at present here at home in Barbados there's no longer any representation for Skoda the last set of cars was 2005 both for the Octavia and the fabias, anyhow we move onwards, when I first got it I couldn't understand why on cold start idle it would tremble before smoothening out as the engine reached temperature, earlier this year I took it to get a kube service and change some hardware EGR valve namely, during the scan this code came up "TCM" we figured out that the computer in the car was not the original one and that it was for the automatic version of a similar model I have 2 keys and could not at first figure out why, let's fast forward,found out a few weeks ago as I attended another technician to have a manual computer installed which I am in the process of returning because it's not coding that the second key which is the driving key is part of an ECU kit ( new to me )
The car idles poor, runs very rich underperforms and I do not think the EGR valve works either as a result of this faulty marriage
I started a search for said ECU kits online found a site in Lithuania but they do not ship outside of the European union also tried eBay (us) nothing as yet
Can anyone provide me with the appropriate guidance please,
I know the potential of these cars, and I appreciate them very much just want to get normalcy so I can move on to do other things
I await your kind response
If it is an auto ecu in a manual then someone has already cloned ecu/copied imobilser data etc to it as car starts and runs. I read using VCDS you can change settings in ECU from auto to manual but have no idea how to. Found this on rosstech for a jetta. https://forums.ross-tech.com/index.php?threads/20338/
Hello there sir, thanks for reaching out and offering help, I'll pursue the link see what happens and send subsequent info to my technician in addition, my concerns are that the car dies not want to climb small inclines, much less hills, also since my car is the 74 kw version I'm uncertain regarding whether or not this Auto ECU came from a 74kw fabia the fact that it's searching for the TCM (transmission control module) on scan tool says a lot about my current issues despite immobilizer data having been copied, but for a certainty I'll check the link you shared, see where it leads and share results
Thanks a million Alasdair1👍
Sorry did I forget to mention that at this very moment i bought a manual computer from someone here at home who purchased it from somewhere in Europe for his fabia even though his ECU was not the problem and when the technician attempted to code it ( for my car) by changing the values/code, think it was 00071 or 73 it changed back, by the way it's a magneti marelli, heard from more than one person that this particular brand is not the friendliest
They preference is Siemens or Bosch which some fabias came with mind you, mine unfortunately did not
In the mean time and in between time can anyone or does anyone know how I might be able to find the manual ECU kit for my car, namely computer, instrument cluster and key barrel please
Thanks in advance
Not sure as your in barbados. I assume the carriage would be expensive if getting it from Europe etc. Are there any scrapyards/autobreakers on the island or on other islands nearer. Think its your best hope. Did read that magneti marelli are not easy and are either auto or manual so dont have all the software to do both hence why the changes revert. Hope you find a solution. Did find a large car breaker in uk that sends international but whether Barbados?? There called Charles Trent https://www.trents.co.uk/#/
Alasdair
Hello again there good sir, thanks in advance, even though there are a few few fabias that has been scrapped I'm doubtful about he working condition of the climate control, but I'll check, I'll also check out your link, I have someone in England who cones home yearly for their holiday 👍👍
Tell me something else sometime ago I emailed Skoda parts located in the Czech republic regarding a replacement ECU and was told that Skoda no longer makes replacement ecu's for our mk1's
But would that also include climate control units?? So it would appear that their inventory retains certain parts and discontinued others, oh dear.🤔🤔
Think he said as of 2020/21
Also I was told by another technician here at home that you can purchase and graded flash file for our cars, can this be confirmed, and that the flash can be done remotely via a special data cable??
I thought I read that somewhere on the web, "said software offering a little over 20hp plus torque"
Recently Browsing 1
