Hub/Bearing bolt torque/angle tightening confusion?
Hi there I have asked this before but cant remember or find post. On the front bearing hub bolt there were three types
One hex which is old style and 200nm plus 180
One multipoint with ribs on face 70nm plus 180
One multipoint without ribs on face/smooth??? Is it 200nm plus 180 or same as ribbed???
I just found the old ones I removed and they were ribbed. I just realised after fitting new springs etc I got three new bolts with one as a spare and they were smooth not ribbed. Seems that they have dropped ribbed one and gone back to smooth
So I went with the 70nm plus 90 without realizing. Hasnt come loose yet but dont want to take the chance.
Alasdair
Edited by Alasdair1
Hi there eventually found old post
Serrated face is 70nm plus 90deg
Smooth face is 200nm plus 180deg
Checked and they are still tight so will remove tomorrow when new bolts come and retorque/angle tighten. Reckon will need a fairly long bar extension to get 180deg.
Still using car but only short journey per day and will keep an eye on it.
Hope havent wrecked bearing but need to do front drive shafts at some point soon anyway. No noise from bearings as yet.
Alasdair
Your figures are right. One thing to watch when you redo them, as the smooth bolt has a set order and it's easy to get the 200 Nm stage wrong:
1. With the car on its wheels, crack the old bolt but don't undo it more than about 90°.
2. Jack it up so the wheel is off the ground, have someone hold the brake pedal, and take the bolt out.
3. Fit the new bolt and do the 200 Nm with the wheel still off the ground and the brake held.
4. Lower it onto its wheels, then do the final 180°.
Don't move the car between taking the old bolt out and the final angle, because the bearing doesn't like carrying weight with the bolt loose. The smooth one is a stretch bolt, so use a new one each time rather than putting the 70 + 90 one back in. For the 180°, a long bar and an angle gauge makes it a lot easier, or mark the socket and the hub with paint and go half a turn.
