Fuel smell - 2 days into ownership
Got my superb estate 2 days ago
Filled up with £50 on weds
Came home could smell fuel
Same again yesterday
Got home from a trip and could smell fuel
Noticed a wet patch on my fuel tank
Went to the garage today
They inspected it and said there is no active leaks
They had it in a garage with the doors shut and running and couldn’t smell anything
But when I’ve had it back this evening
Absolutely stinks
Soon as you open the fuel flap it’s as if you have your head in the tank
It’s so strong
Did a few searches and there’s tons of info online
One think I don’t know Is
There seems to be a gap between the plastic and the fuel filler neck
Is this normal?
Also just pushed the rubber boot back down, would this cause the fuel smell? Or can it be pushed up with tank pressure? Possibly from a faulty evap or n80?
Why is there no fuel filler cap in place ?
Is that how you received it at purchase ?
Edited by Warrior193
question
Removed whilst I was trying to take a photo and workout issue
If the previous owner had consistently overfilled the tank they could have broken the evap system
The EVAP system is strictly designed to handle fuel vapors. When the driver frequently clicks the pump to pack in extra fuel, liquid petrol flows directly down the vapor lines and floods the canister.
Did think that
But now wondering if it was the fuel cap not sealed properly due to the rubber part being up the filler neck
3 minutes ago, RogueFabia said:
Did think that
That is possible too..
(response on other thread)
Just noticed
Hoping it was a simple Fix
But I’m not sure
Was in 3rd
Half throttle and around 2.5k revs to 3k wasn’t smooth increase
So think there’s more to it
