Octavia MKIV 2021 1.5 TSI: fluid around fuel filler opening, is the inside of the neck supposed to look like this?
Hi all,
I have a 2021 Octavia MKIV 1.5 TSI e-TEC (petrol, DSG). Today I opened the fuel flap to refuel and found some liquid in the filler well around the neck (photo attached). I wiped it away before checking whether it was water or petrol, so I can’t say for sure. There was no strong petrol smell, but I’d like to rule out a problem.
I’d also like to check whether the opening is normal. As far as I can tell, there’s no silver flap or valve visible inside the neck. Should there be one? Could an owner with the same model post a photo of their filler neck with the cap off so I can compare?
A few specifics that would help me:
  1. Does your filler neck have a flap or valve inside, and what does it look like?
  2. Has anyone had fluid pooling in this area, and was it fuel or water? What was the cause?
  3. If you’ve had this repaired, was it covered by warranty, and what was the fix?
Extra details: the car hasn’t been washed since the last refuel, and I haven’t noticed any smell or drips under the car.
Thanks in advance!
Edited by OctaviaMK4etec1-5
How my MK3 looks
It’s a strange setup
I reckon it’s water build Up
Just keep an eye on it
That looks pretty typical. The fluid is just water from when it rains - there is a small drain hole at the base of the black plastic surround that allows any that collects to run down through a tube to the wheel arch (you can just about see it in your picture). That will be blocked so just push some strimmer wire or similar through it gently to clear and it'll run away.
