Fuse 7 lack of power steering
I have a Skoda fabia VRs 2004 asz engine each time the ignition is turned of fuse 7 (5) pops instantly unplugged all power steering wires but can’t find what links to fuse 7 can anyone help?
Try unplugging the MAF sensor, that appears to share fuse 7.
Still no luck with it unplugged I am getting an engine code for the maf sensor though and also a communication (p0600) not sure if that’ll help
I'm assuming the car doesn't have an oil level sensor in the sump? That would be on fuse 7 if present.
If not, check for wiring damage in the vicinity of the MAF connector and the 14 way connector adjacent to the left (UK nearside) suspension turret, where the feed from fuse 7 comes through pin 11 on a black/yellow wire.
If none found, try unplugging the two halves of that 14 way, to establish whether the short is before or after that point.
Edited by Breezy_Pete
Will try tomorrow thanks can anything connected to fuse 7 pop it when the ignition is switched to accessories if so could I potentially have a list not a lot on google which I can find
I u plugged that 11 pin connector and the fuse didn’t pop straight away maybe 1 step closer?😁
Good start.
No oil level sensor in sump?
List is what I have told you already:
Power steering pump
MAF
Oil level/temperature sensor if fitted.
There could also be wiring damage shorting the black/yellow wire to chassis (or even another wire possibly).
Don’t think I do haven’t checked if not what’s the way forward because I am also getting a code from the obd for the maf but unplugging that connector has stopped the fuse does that mean it’s on the other side of the connector (female) or closer to the battery
Do you have a multimeter?
I do have a multimeter yes
OK, with those 14 way connectors unmated use meter set on dc volts to work out which half of the connector has pin11 at 12V when ignition is on. I'd imagine it will be the side with female contacts rather than pins.
Then put that connector aside and on the other half measure resistance from pin 11 to battery negative. See if it looks like a dead short.
Then unplug MAF, PAS 4-way connector and oil level sensor if found and see if that short is gone.
If it has gone, reconnect those items one by one to see which is causing trouble.
Finally getting round to doing this today with work and it getting darker at night will try now
One side says 12v (female) the other says 0
Recently Browsing 1
