I did a test on mine today with a Topdon battery tester. My car is a diesel vRS 2.5 years old and 75,000 miles.
The test result ( attached) doesn’t look promising .
Do i have symptoms? Kind of. Mostly the odd low voltage code but it seems to crank strong enough ( even on a frosty morning) and the start stop works flawlessly. I was hoovering the car out the other day with doors open for about 20 mins and the crank did seem a little low afterwards with a tyre pressure monitor fault briefly flashing up on the screen.
Should it be replaced? 2.5 years doesn’t seem long but my car probably has more extreme usage than most.
Anyone else changed your batteries prematurely?
Buy yourself a CTEK MXS 5.0 Battery Charger
Run it on the Recond option.
Brought my battery back to life after suffering similar issues to your own, and it's worked flawlessly since
38% health while SOC at >95% is pretty low and tends to suggest your battery is suffering from hard sulphation - which will probably not be fully reversible.
Internal res looks OK.
A recovery charge programme may help, but approaching winter could well finish it off.
I have used a smart charger a few times. Didn’t make any difference, offen says the battery is full after only 30-40 mins.
Resistance not a little high? For comparison i tested the same battery in a friends car but a year older. His read over 600 amps and a resistance of 3.7 millohms.
From memory, anything below 8 mOhms is ok.
The CTEK worked wonders for me. The Recond mode gave my battery a completely new lease of life
I might get one for experimental purposes to see what happens but i suspect my battery is quite worn. According to OBD11 the starter has been activated 25,000 times and total energy throughput 14,000ah.
What was happening with your battery and how old? Did it last much longer?
My battery almost died at around 4 years old, set off a flood of warning lights, all of which I could clear using OBD11 barring one, the airbag light, which needed the module software updating to remedy that.
Tried simply charging it using the CTEK first of all, and whilst on paper (so to speak) that brought it back up to voltage, it still seemed to under perform, start / stop never functioning, the odd random warning light etc
So I tried the Recond mode and ever since it's worked almost flawlessly. Start / stop functions as it should and warning lights are a thing of the past (touch wood)
Now I hook it up on a trickle if I'm ever plugging OBD11 in for any reason, other than that I intend to use the Recond mode once a year, as is suggested by CTEK.
I still have the battery in question, this happened almost a year ago now
Edited by scotthugh3s
