Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
Hello everyone!
I've noticed that my serpentine belt has got a mark on the flat side of it, (crap blurry picture attached) which i suspect is the cause of my squeaking I hear when its wet or humid outside
but I have also noticed that the tensioners sockets are stripped (and the cover is missing, somehow), so I'm going to have a new tensioner as well
PXL_20261115_170550270_exported_223962.jpg PXL_20261115_170550270_exported_69542.jpg
What brands should I get/avoid? Currently planning on buying through skoda-parks.com
I was going to buy an INA tensioner because it being OEM, but I've heard the sockets being made from mild aluminium makes them easy to strip, so I was wondering if i should get the SKF one instead? Ive heard good things about it but of course I don't yet know how it differs when it comes to installing it and getting the belt on properly (this will be the first time I've serviced a belt but i have seen a mechanic walking through with the OEM tensioner)
Similar situation with the belt, I was initially going to go with the Gates one as I seen a lot of people swear by them but I've seen a few comments in recent years saying that they have gone down the plug hole with their quality
I can also buy the Contitech one, which from what I understand is made by Continental, or I could get the Skoda one but its also double or quadruple the price of the other two
If you have any experience with these brands or products I'd love to hear your opinions/experience and recommendations
Thanks for your time!
The pulley screwhead appears to be a 12-point, XZN type, not Torx (6-point). Try picking out all the loose bits of debris and using the correct tool. Not 100% sure on this, but a bit of cleaning out and a better photo may confirm. You may then be able to use that to release the belt tension (and so not need a new tensioner at all).
I've never known of the existence of the Torx socket in the aluminium, always released via that pulley screw. It won't come undone with the amount of torque applied to relieve tension on belt, it may even be a left hand thread, I forget.
Edited by Breezy_Pete
hmm yes defiinty worth a try! if i dont have to buy a new tensioner then ill probably get an OEM belt instead
