campaign
When I started the car this morning.
It came up on the screen that there were 2 campaign messages.. I pressed the first one and I was told to scan the QR code that appeared then press ok. The same with the second message. Then the screen went to normal. Does anyone know what this is about .
The only thing that I can see different is in the Skoda app you can click on smart home and generate a key. How you use it I don't know
I had one of those messages, along with the normal software update message (which I think is now solved, but that's another story!)
I wasn't able to scan the QR code with my phone as I was driving, and then it went away. As you say, the only change in the app is the profile / smart home section which seems to be offering to link my car to my non-existent smart home app. No idea what this is about unless it is offering to warm the car up before you use it?
I followed the instructions in the app to generate a key,then it said to copy it and paste it, only problem is I couldn't find out where to paste it. Google suggested suggested using Google assistant app but that has now changed to Gemini and you can't use that.
This page sets out the scope of the information that can be made available via a smart home app or any other app provided its developer does the necessary work:
https://public.api.connect.skoda-auto.cz/docs
Thank you for the reply mumpsim. That is all as clear as mud. I can't see many average owner making use of that feature
I suspected the QR code was to install the MySkoda app on your phone if it wasn't already there. And the Home Assistant link presumably just gives you access to the MySkoda app via Home Assistant?
It seems overkill to me, although it may be useful for charging an electric car perhaps. This Home Assist stuff seems to be asking for trouble! I had a new shower installed in my bathroom recently, which could be linked to my WiFi! Even the plumber admitted the idea of being able to remotely control your shower seemed anything from pointless to dangerous! But if your kids hog it, perhaps you'd want to turn it after after 10 minutes??
