Heated mirrors not working, both sides
Hi folks, anyone got any ideas on this? I think my heated door mirrors were working last winter, assume so but can't honestly remember. Pretty sure I would have noticed if not.
With the recent cold snap I've noticed they're not heating up, same both sides. I've had both doors apart to test, and in each case I'm getting 12V on the black/red output pin of the door module and earth continuity on the black/blue pin. Wires are continuous, and mirror elements read a useful number of Ohms, somewhere around 5-6 iirc which fits the 27W power consumption. Connecting the mirrors direct to a 12V battery they both work nicely.
All the other mirror functions - motors, lights - work as normal.
I found a Reset button in VCDS for the door electronics modules, so did that.. no change.
Sadly, gone are the days of fuse>wire>switch>mirror, and now there's at least two computers involved(!) which is way above my pay grade, but it seems unlikely for both door modules to have packed in simultaneously (or at least within a very short space of time).
For the time being I've wired the mirrors out to a 12V supply with fuse and switch, which works fine but means extra wires running around, but does this ring any bells with anyone?
Does your mirror adjustment switch have a position marked with a little heated mirror symbol? Easy to leave that switch on L or R if you've been adjusting them.
Mine has that, plus the extra position for pulling the mirrors in. I wonder if the switch could perhaps only partly connect,so 12V appears but not the current capacity?
Recently Browsing 2
