Bet
I've fluid runs down my glove box and dripping onto the mat, any ideas where it could be coming from? 2023 tsi
Welcome. Fluid as in something that is not just water? Any smell to it, or dare I ask any taste?
Possibly rainwater from air intake in front of windscreen - check that scuttle drains are clear.
The first time it happened, water/ fluid ran down the front doors. The second time it ran from just above the glove box. Skoda have "looked" at the car but found it to be dry, so it's not faulty. They have "looked at the scuttle and said it was dry but obviously it could be blocked further down. Whatsnthe best way to check it please.
The first time was after torrential rain,so we thought it was rain coming in. The second time we hadn't had any rain for two days but we'd jet washed it two days before ( purposely to get it wet). The car is always parked on our drive on an incline ( engine up).
Edited by Bet
That could be the problem if it's anything like the stupid design of my Audi TT. With that, if the scuttle drain gets blocked the water overflows the scuttle and has run into the car.
With you having the car facing uphill then this is more likely to happen as there is less of a barrier to stop the water running in.
If the drains are clear you should see water running out under the car if you run a hose into the scuttle area.
Recently Browsing 1
