Battery issue or?
Hi all
For about a week or so the temperatures have dropped significantly (from 10-15 degrees C during the day down to negative values during the night). When I start my car for the first time in the day either in the morning or later I switch on the ignition, wait a few secs and then press the brake and start the engine and at that moment I get a warning such as ACC unavailable, manoeuvre braking unavailable and they disappear in 1-2 seconds and everything is working. The car is starting normally, the battery is an original VW 75Ah battery fitted brand new 2 years ago by an authorized dealer. My question is could this be a momentary drop in voltage and should I be worried since I have some trips lined up in the next couple of weeks?
Could be, the cold weather is hard on a battery. It could also be that certain sensors are a bit slow to respond during very cold weather hence the 2-3secs delay. My Octavia mk2 idle revs during the last cold spell were high but seem to have returned to normal now its above freezing.
Alasdair
Recently Browsing 3
