Wheel spin on moderate throttle
Hi. My 1.5 dsg is prone to wheel spin when trying to accelerate a LITTLE briskly at low speeds. Eg when joining a roundabout from stationary or pulling out from a junction. Never encountered this in over 40 years’ driving. Skid control doesn’t even engage. Any thoughts. Still under warranty
Cheers
Welcome to the forum.
What tyres does it have on?
Are the tyre pressures correct?
Your ABS Wheel speed sensors could be dirty and or broken.
Your tires made of harder rubber depending on make and type.
Tyres over inflated for the weight of the car.
Driving skills? And I don't mean this rudely. If you know the car is powerful enough to spin off the line. Learn to get off the line and immediately short shift to second. Or get accustomed to pulling away cautiously. Does the car do it in the dry, or the wet?
Do you have the habit of stamping on the throttle. The car can't change what it does. But the driver can adapt to make sure the car behaves. Its all about experience.
Don't get that on my 1.5DSG. It is a powerful FWD though so if you are expecting to simply stamp on the throttle you will get some wheelspin, just like in any FWD car.
Plenty have made the same comments over the years on this forum as the op but usually in the Karoq section. And the questions @Warrior193 asked are the common ones to ask.
Edited by Evolution13
If the wheels are spinning at moderate acceleration it could be as said tyres or greasy road conditions especially at roundabouts/slip lanes. If no traction control warning shows it could be that in certain driving modes its disabled but worth getting it scanned to see if anything has failed and caused it to be disabled. On all my skodas the traction warning light comes on even if its a minor wheel spin. There all manual so not sure re DSG.
Alasdair
Recently Browsing 1
