Fifth gear popping out (gearstick)
Hi all, 1.9 TDI 2005 estate. I assume all original parts for gear system.
Started a couple of weeks ago on the motorway; the gearstick popped out of fifth and so the revs shot up etc. Put it back in and all was well (this is Newport to Tenby).
On the way back started fine then again once we'd been going an hour or so, did it again. This time, several times. You can hold the gearstick and almost feel it resisting, like something wants to pop it out.
Didn't need to use it subsequently around town once back home; gears one to four are absolutely fine. Had it booked at a garage with a two week wait time; they took it for a test drive but it behaved normally.
I took it out in fifth for the first time today and it seemed fine too, though again after half an hour or so I'd say the gearstick 'twitched' in fifth (a small movement) but didn't disengage. Then was fine.
Any ideas or anyone had this?
Your issue is most likely to be excessive wear in the gear cluster, although this can sometimes be due to faulty engine mounts on some older vehicles.
Does this this tend to happen more when you accelerate - or when you lift-off the throttle ?
When it does happen, it tends to be either when already in gear and just driving steady (ie random) or, on the occasion it did it several times, on acceleration.
If that helps diagnose!
Might be worth resetting gear lever cables and check that the selector on Gbox is not seizing especially the plastic triangle shaped bit.
Alasdair
Might be worth checking gearbox oil level/condition as well as its a 2005 car. Could be low
Alasdair
Recently Browsing 2
